Mephistopheles8
Dec 02, 2019Initiate
RAX 120 wireless SSID not shown
I Just set up this loveky router, i can see the SSID on all devices except one laptop. This Asus laptop doest see the 2.4G or the 5G wirless networks even though it was working fine with the previous ...
- Dec 02, 2019
What wireless card is in this laptop? intel cards had issues when the AX standard first came out. If its an intel card, go to the intel website and download an updated driver for it. Don't rely on the asus website to have the most current driver. They rarely do.
another option you can try is to disable wireless AX. Some older cards have issues with AX.
I'd start with checking your driver first though.
Dec 02, 2019Guru - Experienced User
Mephistopheles8
Yes that worked like a charm. I updated the wifi driver directly from Intel and all of the router wireless SSIDs appeared.
Thank you
- plemansDec 02, 2019Guru - Experienced User
Glad to hear it fixed the problem!
