tgandy2008
Oct 31, 2022Follower
RAX 120
I am using a jetpack from Verizon and need to back feed my LAN. Will the USB ports on this router work to back feed my service into it??
Nov 01, 2022Guru - Experienced User
No, you can't connect the jetpack to the RAX120's usb port and expect to provide it ethernet.
If you search the verizon jetpack forum, many members have tired to connect their jetpacks to a router without success.
If you're needing something like this done, I'd check with verizon about upgrading your jetpack to a different model that supports ethernet
