dplara75
Feb 01, 2021Follower
RAX-15 does not allow devices to reconnect until a reboot.
I have devices that show attached to the RAX15 WiFi router in the Nighthawks device manager, but the apps that control the device cannot manage the device until the router is rebooted. For example, ...
Feb 01, 2021Guru - Experienced User
Whats your full setup?
you have the RAX15?
what modem/gateway is it connected to?
you also put the GSM7248v2 in your signature?
What other devices/switches/routers are running on your network?
