SenseB12's avatar
SenseB12
RAX-15 Router extremely poor wireless performance
I have been having problems with my RAX-15 router wifi speeds. In short, the router performs fine after it is restarted, but gets extremely slow after a short uptime. I haven't found any solution oth...
  • SenseB12's avatar
    Jun 04, 2022
    After some experimenting, I have found that the problem can be solved by reverting to older firmware. Firmware V 1.0.4.100 (and earlier) seems to work normally, my speed is good after more than 24 hours of uptime. Firmware V 1.0.10.110 and V 1.0.11.112 both have the problem, so it seems to have originated in V 10.0.10.110 and not been fixed since.
    This is more of a workaround than a solution, but at least I can use my wifi. I also assume that most people are using the latest firmware without issue, so I'd still love to know what combination of settings or hardware with the latest firmware is causing the problem. But I'll just post this for now in case anybody else is having this problem:
    If your RAX 15 WiFi is fine on a fresh start but suddenly slows down after a few minutes, and your connection still reads strong, revert to firmware V1.0.4.100!
