FPSUsername
Apr 14, 2021Aspirant
RAX 20 bug (internet works, but LED is solid amber)
Hello, I've experienced this odd bug where the internet status LED is stuck on solid amber while the internet works fine (after the network hickup it experienced). It's very very unfortunate ...
FPSUsername
Apparently the pictures didn't get uploaded correctly. Here they are. (If only it was possible to edit a post, like on every other forum)
Router LED status
FPSUsername
Great, it's a mess. Here's a link to the pictures hosted on imgur.
- plemansApr 14, 2021Guru - Experienced User
you're pulling a 192.168.2.* address.
What modem/gateway is it connected to?
- FPSUsernameApr 14, 2021Aspirant
It is a KPN Box 12 modem/router from my ISP.
That device is a gateway/router all in one device.
do you have it in passthrough/modem only mode?
Or the netgear in access point mode?
Or the netgears IP address in the KPN's DMZ?
Otherwise you're in a double nat. It can cause issues with the led/internet status.
