casperha
Aug 09, 2021Aspirant
Rax 200 配置 Error: Unable to establish WAN aggregation"
大家好
我的Rax200配
Internet setup , Set Multi-GigInternet (1Gbps + 1Gbps)
but system show "Error: Unable to establish WAN aggregation"
Firmware Version V1.0.4.120_1.0.61
我是用2家不同的网路供应商,
配置改了很多也不能正常使用。
WAN aggregation isn't dual wan.
They're different processes and the RAX200 doesn't have dual wan capability.
Its for hitting speeds faster than 1 gbps from a single source.
- casperhaAspirant
Hi Guru
many thanks .
may i know can i add more modem or router , make it work ?
example : 2 router and connect switch which have link aggregation ,and then plug in wan aggregation?
thanks.
- Retired_Member
Is there any chance that balance-rr can be added to these routers via a firmware update so it can connect to something like a VM Superhub 4 which only supports aggregation using that protocol?
