larkhillhouse
Oct 02, 2023Tutor
RAX 200 and connecting to sky broadband
hi guys I've had my RAX200 for a couple of years and have been on BT broadband. just switched to sky broadband and can't now connect . i'm sure its something simple to change in the settings as ha...
Oct 02, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Are you using the Yellow Internet port or the Multi-Gig port on the RAX for it's internet conenction to the ISP modem?
Your modem model, I'd use the Yellow WAN Port and ensure the RAX web page is configured for it.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- larkhillhouseOct 11, 2023Tutor
hi
its running v1.0.10.140_1.0.79
thanks
