dalepbaker
Mar 22, 2020Aspirant
RAX 200 AX11000 Firmware
Logged into my router and it said new firmware available
I have installed 1.0.2.8
but newer available but wont download
How about a updated firmware link so I can manually download and install
1 Reply
Greetings,
Recommend you not use Auto-Check and Update or the automatic update feature on the router. Nor would I use an App.
Updates should be performed manually, from a system connected via ethernet, and on your terms.
Downloads for the RAX200 Here
