C4mth4
Dec 04, 2019Aspirant
RAX 200 blocked region
Hello everybody, I bought an used RAX200 and when i plug it i discover the region is blocked at "United States", but i want to change to France. (Sorry for my bad english) Thanks for your...
psychopomp123
Dec 07, 2019Luminary
OP, Try installing TelnetEnable on your pc, and if you can successfully telnet into the RAX200 then use burnsku command to change the router's region to WW (world wide).
github.com/insanid/NetgearTelnetEnable
- michaelkenwardDec 08, 2019Guru - Experienced User
Do people really need to install third party software to enable Telnet on the RAX 200?
You can do this on some other Netgear routers without adding anything.
Just login to:
http://routerlogin.com/debug.htm
then enable Telnet and take it from there.
- C4mth4Dec 08, 2019Aspirant
Thank You michaelkenward , but i haven't case for enable telnet in debug mode :-(
