dglsmcd_USMC
Aug 05, 2020Luminary
RAX 200 Firmware Update 1.0.2.98
New firmware for the RAX 200 is available here: https://kb.netgear.com/000062168/RAX200-Firmware-Version-1-0-2-98 New Features and Enhancements: Supports the NETGEAR automatic time zone de...
CAmbr52342
Sep 10, 2020Tutor
Ever since I updated to this firmware the Nighthawk app will not detect my router. It states “Router not supported.” I can connect with Anywhere Access using my WiFi. Also, I can’t access the router set-up page from any device. Nothing works. The router itself is working fine. Any help would be appreciated.
- dglsmcd_USMCSep 10, 2020Luminary
RAX 200 Firmware Update 1.0.2.98 has since been removed from the NG download page-the current download is the previous firmware 1.0.2.88 which I would recommend installing to help out in your situation-make sure to do a hard reset and reconfigure from scratch-do not use any saved configurations.
http://www.downloads.netgear.com/files/GDC/RAX200/RAX200-V1.0.2.88_1.0.50.zip
- dglsmcd_USMCSep 11, 2020Luminary
Currently NG has restored access to firmware version 1.0.2.98 for the RAX 200. Will test this "new" version to see if there are any fixes/improvements
Too quick on the trigger-the download link for the "new" 1.0.2.98 firmware for the RAX 200 does not work on the NG download page for the RAX 200. Any news on what is going on with RAX 200 firmware Christian?
