meinico
Jul 05, 2022Tutor
RAX 200 NEW FIRMWARE 1.06.78
Good day, i have the router RAX200 to about 1 year, the cost of the router is more expensive about 500 euro!!!! I think that the performance the configuration and the speed are very high, but i th...
Jul 05, 2022Guru - Experienced User
Have you tried enabling IPv6 on the router?
v.78 isn't new and isn't seen on NGs web page. Did you get this from NGs download page:
https://www.netgear.com/support/product/RAX200.aspx#download
or thru the routers web page FW update section?
meinico
Jul 05, 2022Tutor
Thank you for the suggestion, the correct new firmware is 1.06.138.
I do not need the IPV6 connection, becuse i do to enable it?
Where is the function of IPV6?
My configuration is: ONT NOKIA of the internet provider, RJ45 from ONT to ROUTER RAX200 in the wan port(yellow)
internet configuration is PPOE with username and password of the internet provider, after that there are some client
with IP RESERVED ADRESS, wireless configuration, some port forwarding and VPN connection for my smartphone.
With the indicated configuration the router is rock solid with firmware 1.05.132, when i l see the new firmware 1.06.138
on the site netgear, i have downloaded it, i have factory reset to the router, after that i have UPGRADING the router with the new firmware and inserted the configuration indicated above, the router is ok until there is a reboot, in this case stopped some function how VPN.
Because i should activate the IPV6 connection?
Than you
