dglsmcd_USMC
Sep 28, 2020Luminary
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38 Christian_R <New firmware is found. Do you want to update the firmware? (Yes) (No)
Current GUI Language Version: 1.0.2.88_2.1.46.1
New GUI Language Version: 1.0.2.102_2.1.46.1
Current...
- Sep 29, 2020
Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
Retired_Member
Sep 29, 2020I haven't done a factory reset but after installing this firmware, my NTP time is the international date line. I have tried setting it to my local time zone, eastern time with daylight savings checked and reboot each time. It reverts back to the international date line and won't keep my selected time zone.
- dglsmcd_USMCSep 29, 2020Luminary
- Retired_MemberSep 29, 2020
Thanks I'll do that now.
Semper fi
