dglsmcd_USMC
Sep 28, 2020Luminary
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38 Christian_R <New firmware is found. Do you want to update the firmware? (Yes) (No)
Current GUI Language Version: 1.0.2.88_2.1.46.1
New GUI Language Version: 1.0.2.102_2.1.46.1
Current...
- Sep 29, 2020
Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
dglsmcd_USMC
Sep 29, 2020Luminary
Retired_Member
Sep 29, 2020Thanks I'll do that now.
Semper fi
