dglsmcd_USMC
Sep 28, 2020Luminary
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38 Christian_R <New firmware is found. Do you want to update the firmware? (Yes) (No)
Current GUI Language Version: 1.0.2.88_2.1.46.1
New GUI Language Version: 1.0.2.102_2.1.46.1
Current...
- Sep 29, 2020
Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
RajaDaja
Oct 02, 2020Luminary
Who has updated to f/w 1.0.2.102_1.0.56
Not much chatter going on about this latest F/W........Any word on ipv6? Is it functional? What about connectivity? Stability? Thanks
- AmbassadorfFunkOct 07, 2020Initiate
I'm continuing to have issues with the connection dropping. Restarts only fix the issue for a few days before happening again. Support is having me disable AX and change my MTU size. I fail to see how this will help the router stay connected when bot my wireless and wired connections are dropped. The router itself says there is no longer a connection.
I would not recommend this router to anyone for purchase at this time.
