dglsmcd_USMC
Sep 28, 2020Luminary
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38 Christian_R <New firmware is found. Do you want to update the firmware? (Yes) (No)
Current GUI Language Version: 1.0.2.88_2.1.46.1
New GUI Language Version: 1.0.2.102_2.1.46.1
Current...
- Sep 29, 2020
Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
RajaDaja
Oct 02, 2020Luminary
Who has updated to f/w 1.0.2.102_1.0.56
Not much chatter going on about this latest F/W........Any word on ipv6? Is it functional? What about connectivity? Stability? Thanks
AmbassadorfFunk
Oct 07, 2020Initiate
I'm continuing to have issues with the connection dropping. Restarts only fix the issue for a few days before happening again. Support is having me disable AX and change my MTU size. I fail to see how this will help the router stay connected when bot my wireless and wired connections are dropped. The router itself says there is no longer a connection.
I would not recommend this router to anyone for purchase at this time.
