dglsmcd_USMC
Sep 28, 2020Luminary
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38 Christian_R <New firmware is found. Do you want to update the firmware? (Yes) (No)
Current GUI Language Version: 1.0.2.88_2.1.46.1
New GUI Language Version: 1.0.2.102_2.1.46.1
Current...
- Sep 29, 2020
Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
lagr
Oct 07, 2020Guide
I have major issues with my RAX200/12 router. I have three Macbooks, Air 2019, Air 2020 and 16" 2019. The 16" works perfectly fine with my router but BOTH Airs literally takes an hour every morning before they get a stable connection. During that hour they constantly connects and disconnect (when they are connected, the signal is full). After an hour their connection is stable for the rest of the day.
Both Airs work fine with all other networks I connect them.
I have similar problems with my phone and my iPad. The phone's (Android) connection is quite stable but regularly drops for a few seconds. On the iPad I must manually connect and then it stays connected for a few minutes/until I put it away - and then when use it again I have to manually connect.
I also have three brand new D-LINK surveillance cameras (DCS 8300), They flat out refuse to connect, forcing me to create an unencrypted network.
Finally, every time I restart the router it is factory reset. WTF!?
The support suggested I should downgrade the router to a previous version of the FW but couldn't explain why.
At the moment, this router is horrible.
- YousefOct 07, 2020GuideI just updated my router and I hope this will be stable version but not I will go to the brevious one .88 at less stable connection without any issues.
If someone face any real issue please type it here.
Best regards.- RoamingBisonOct 30, 2020Aspirant
NTP is broken once again in firmware V1.0.3.102_1.0.56. I will try to revert to the 1.0.2.102 version to see if it works. Why can't they get this right? This bug kees bringing down my network and it's seriously interfering with my work.
- roger1955Oct 30, 2020ApprenticeOnly issue since installing latest F/W is, router goes into a vegetated state every 3-3 days. It just stops doing the router thingy and drops offline. Back on F/W Ver 1.0.2.8
