dglsmcd_USMC
Sep 28, 2020Luminary
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38 Christian_R <New firmware is found. Do you want to update the firmware? (Yes) (No)
Current GUI Language Version: 1.0.2.88_2.1.46.1
New GUI Language Version: 1.0.2.102_2.1.46.1
Current...
- Sep 29, 2020
Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
Yousef
Oct 07, 2020Guide
I just updated my router and I hope this will be stable version but not I will go to the brevious one .88 at less stable connection without any issues.
If someone face any real issue please type it here.
Best regards.
Best regards.
RoamingBison
Oct 30, 2020Aspirant
NTP is broken once again in firmware V1.0.3.102_1.0.56. I will try to revert to the 1.0.2.102 version to see if it works. Why can't they get this right? This bug kees bringing down my network and it's seriously interfering with my work.
