dglsmcd_USMC's avatar
dglsmcd_USMC
Luminary
Sep 29, 2020
RAX 200 New Firmware Update 1.0.2.102_1.0.56
FURRYe38  Christian_R    <New firmware is found. Do you want to update the firmware? (Yes) (No) Current GUI Language Version: 1.0.2.88_2.1.46.1 New GUI Language Version: 1.0.2.102_2.1.46.1 Current...
  • dglsmcd_USMC's avatar
    dglsmcd_USMC
    Sep 29, 2020
    Without the hard reset I had the same result-did a hard reset and configured from scratch (no config file used from a backup) and all is good with NTP-the router selected the correct timezone (CDT in my case) with adjustment for daylight savings time auto selected.
