JNollett
Jan 01, 2021Tutor
RAX 200 Power Supply
Hi Does anyone know where I can buy a replacement PSU for the UK version of the RAX200? Thanks
Jan 01, 2021Guru - Experienced User
netgear doesn't sell replacement power supplies. I usually get them off amazon/ebay.
You just make sure they have the same output voltage, polarity. The amperage can be more but I wouldn't go less.
