JNollett
Jan 01, 2021Tutor
RAX 200 Power Supply
Hi Does anyone know where I can buy a replacement PSU for the UK version of the RAX200? Thanks
michaelkenward
Jan 02, 2021Guru - Experienced User
JNollett wrote:
Hi, I saw these and many others, but they have a central pin in the adapter, whereas mine doesn’t.
The manual shows an input with a central pin. It is a part of the 19-volt range. I have one in front of me. The symbol on the label is identical to that in the manual for the RAX200.
I have used a dozen or more Netgear adapters. I even have a few that are just like the one used in the RAX200. It has the usual "plug". I can't see that Netgear has invented a new plug just for the RAX200.
By the way, why are you looking for a new adapter. Did you have one that blew up? Or have you imported one from the USA?
Here's an idea. Use the one you got from the USA. It says 120 volts on the thing? Surprise surprise, there is a very high probability that it will work in the UK.
How do I know? Been there done that. As have several other people.
Plug it in. Did it go bang? No? Then try it on your router.
By the way, one of the devices I linked to has exchangeable tips that should fit most know devices.
JNollett
Jan 11, 2021Tutor
Hi
I bought it off eBay with no PSU, so I guess it must be an import. The adaptor is 5.0 x 3.3mm with no central pin. I'll try buying one from the US as Netgear will not sell spare PSU's.
Thanks
