mlotov83
Oct 24, 2019Star
RAX 200 slow LAN and Wireless
Hello team, First time on here. I purchased a RAX 200 and have had slow issues with LAN connections of not being able to obtain full downloadspeeds through the router. It cuts to half of my 1gig ...
Matrix7
Nov 06, 2019Tutor
I'm having the same slow speeds both hardwire and wifi. Spent 3 hours with tech support with no solution.
- catalambanoNov 06, 2019Star
Try turning the dynamic qos on and off. For me it worked, although I have to repeat the operation every time I change something in the router menu.
- YoungSpicketNov 08, 2019StarThat would mean the $600 router is broken my guy. Netgear should get everyone a refund as this is one of the most severe defects in a shipped piece of network hardware I can recall. Meanwhile the RAX120 is still on a “hotfix” to fix its severe issues.
