mlotov83
Oct 24, 2019Star
RAX 200 slow LAN and Wireless
Hello team, First time on here. I purchased a RAX 200 and have had slow issues with LAN connections of not being able to obtain full downloadspeeds through the router. It cuts to half of my 1gig ...
mlotov83
Nov 20, 2019Star
RMA router up and running. So far so good. I'm recieving LAN speeds of 800mb down. It's up almost 350mb from replacement router. It came with original launch firmware installed. Against my gut I updated the firmware and so far results are the same.
AX - on
Smart Connect - On
QOS - off
Wifi speeds on iPhone 11 Pro Max - 414mb - I am a dissapointed at these speeds as I thought this speeds would be higher since the phone supports new wifi AX signal. Maybe someone can provide somehelp. 22 devices connected to the router.
All connections are stable. I'll update again in a couple of days to see if these tests hold true.
catalambano
Nov 20, 2019Star
mlotov83 wrote:RMA router up and running. So far so good. I'm recieving LAN speeds of 800mb down. It's up almost 350mb from replacement router. It came with original launch firmware installed. Against my gut I updated the firmware and so far results are the same.
AX - on
Smart Connect - On
QOS - off
Try to change some settings (and then maybe bring it back to the original setup) and check if the cable speed remains high or decreases.
