BeefMaster
Feb 20, 2020Tutor
RAX-35 causing frequent disconnects with Surface Pro 5th-gen
I picked up a Nighthawk AX4 4-Sream AX3000 (model RAX35) a few weeks ago as a replacement/upgrace from a TP-Link Archer. For the most part, it's worked well, with one glaring issue - it essentially h...
lucask
Jul 16, 2020Aspirant
I am still having this issue, what is the resolution? Has anyone been able to connect their surface pro consistently without BSOD?
Lucas
Lucas
Rodney1008
Jul 17, 2020Aspirant
Although not a good solution. I found that if I enabled a guest account, did not put any security on it, and disabled SSID broadcast to make it somewhat secure I was able to stay connected. Apparently the problem is with the security. I had another solution provided that I didn't expect. I had a lightening strike which fried the Netgear. I put the old TP Link back into use 2 weeks ago without any issues. I'll be purchasing a new TP Link.
