BeefMaster
Feb 20, 2020Tutor
RAX-35 causing frequent disconnects with Surface Pro 5th-gen
I picked up a Nighthawk AX4 4-Sream AX3000 (model RAX35) a few weeks ago as a replacement/upgrace from a TP-Link Archer. For the most part, it's worked well, with one glaring issue - it essentially h...
mavledger
Aug 29, 2020Guide
I experienced this as well, Netgear had no real solution and switched back to my TP-Link that works flawlessly. It's unfortunate that a much cheaper router can provide better stability than the RAX35.
