juann24
Apr 19, 2020Follower
RAX 35 keeps disconnecting
I recently statred having issues with the router randomly disconnecting all my devices then a few seconds later it reconnects. There is no pattern happens at all times fo the day and neve rhad issue...
mavledger
Jul 01, 2020Guide
Same thing is happening here with this model. Constant disconnects where the wireless disappears and a reboot of the router is required for the wireless to show back up.
This has the newest firmware as well.
- zasinzebraJul 19, 2020Initiate
I also have the AX4-RAX35 and the wifi stops broadcasting every few hours (this has been happening for the past month, maybe after the latest firmware update). The lights on the router seem to not change or indicate any problem. The connection seems relatively stable (based on my camera continuing to work) when I am away from the house, but the broadcasting stops when I try to actively use the interent on my phone or other device.
