juann24
Apr 19, 2020Follower
RAX 35 keeps disconnecting
I recently statred having issues with the router randomly disconnecting all my devices then a few seconds later it reconnects. There is no pattern happens at all times fo the day and neve rhad issue...
Christian_R
Apr 22, 2020NETGEAR Employee Retired
Hello juann24 - I have sent you a message. Please check your inbox.
Christian
Mjnight
Aug 21, 2020Aspirant
Same issue started happening to me this month onwards. Very frustrating.
I have at&t modem 300 mbps plan.
Netgear asking $99 for diagnosis when my hardware warranty is still there!
Can any suggest any settings?
- mavledgerAug 22, 2020GuideNo, they wouldn't help. I refused to pay for support for their level 1 guys to tell me that there is nothing they could do. Their warranty is horrible for backing up their product. I factory reset as well as applied an older version firmware. I ended up applying a Linux based firmware that I've been testing since they wouldn't back their product.
- Eagle-TwoAug 24, 2020Apprentice
The disconnect issue with the RAX35 / RAX40 router looks to be related to the 1.0.3.80 firmware. I haven't found a way to report a firmware bug to Netgear. Perhaps the issues posted in these Netgear community discussions are being written up as bugs for the QA team to review and developers to correct.
