juann24
Apr 19, 2020Follower
RAX 35 keeps disconnecting
I recently statred having issues with the router randomly disconnecting all my devices then a few seconds later it reconnects. There is no pattern happens at all times fo the day and neve rhad issue...
mavledger
Aug 29, 2020Guide
No and no response from Netgear on this either. Tech support offered no real solution either.
Eagle-Two
Aug 29, 2020Apprentice
I think the RAX35 and RAX40 routers may use the same firmware. I see in the "RAX40 Firmware 1.0.3.80 Crash/Bug Log" discussion they are testing a beta firmware for the RAX40.
I recently had all of my 5Ghz devices disconnect from the router and wouldn't reconnect until I rebooted the router. 2.4Ghz connections didn't have an issue.
- mavledgerAug 29, 2020GuideSame here but all of my devices are on 5ghz. Hopefully they get new firmware out there quickly. You'd think this bug would have cropped up in testing. Quality control seems to have gone of vacation.
