Universal_Fox
Sep 16, 2022Aspirant
RAX 35 not working
I got this router around August 2021 and it was working completely fine until it stopped working, i was using it as a wifi extender since we dont use modems in my country. I've tried the reset button...
Sep 17, 2022Guru - Experienced User
what happens when you push and hold reset?
What does the power led do?
Have you checked to see if the power supply was switched with another device?
- Universal_FoxSep 17, 2022Aspirant
nothing happens when i hold reset
the power led doesn't light up only the 2 led's i mentioned above do when ever i turn it on
and its the original power supply
