Universal_Fox
Sep 16, 2022Aspirant
RAX 35 not working
I got this router around August 2021 and it was working completely fine until it stopped working, i was using it as a wifi extender since we dont use modems in my country. I've tried the reset button...
Sep 17, 2022Guru - Experienced User
what happens when you push and hold reset?
What does the power led do?
Have you checked to see if the power supply was switched with another device?
Universal_Fox
Sep 17, 2022Aspirant
nothing happens when i hold reset
the power led doesn't light up only the 2 led's i mentioned above do when ever i turn it on
and its the original power supply
