chrisagardner63
Aug 15, 2022Follower
RAX 40 - FIrmware Update
My router got a firmware update last month. V1.0.4.102_1.0.1. The router has been restarted. My issue that I bought a wireless printer, got it setup on my wireless SSID. Since the firmware upd...
michaelkenward
Aug 15, 2022Guru - Experienced User
chrisagardner63 wrote:Since the firmware update, The printer is connecting to a SSID that has been disabled and deleted.
Freaky. Maybe you need to hire an exorcist.
Does the anonymous printer have a "reset"option?
The usual way to fix wifi printers is to find the printer maker's utility, the software that runs on your operating system. Then use that to connect the printer to the wifi.
The router just broadcasts wifi. It is then down to the printer to play ball. There isn't much that you can do on a router, beyond fixing it to a particular IP address, that affects what the printer gets up to.
Where possible, using the WPS feature can simplify things.
