Ghostdragon87
Oct 20, 2019Tutor
RAX 40 Question Before Buying
So currently i'm using a Netgear WNDR4300v2 router and planning to upgrade to the RAX 40 but have some questions/concerns. 1. Do I need to download the nighthawk app to setup/update/configure the RAX...
Oct 20, 2019Guru - Experienced User
I've got a RAX200 so I can only go off that. It should be the same/similar.
1. You can set it up with a pc. The manual shows how. Its just the quick instructions state to use the app but the normal gui setup works fine. I've done it several times with my rax
2. Mine works fine. There was an issue with chrome but its since been resolved.
I've had zero issues accessing the gui.
3. You can disable auto update within the RAX200 menu. I couldn't find anything in the manual about the RAX40 but it wasn't in there for the RAX200 either. I'd imaging its the same as the manuals were fairly close to the same.
