Lapidus
Aug 06, 2019Tutor
RAX 40 range improvement
Hey guys. I have a AX4 and overall am not impressed with the range of this modem. I have a 4000sq foot house and purchased this because I read it would be sufficient for it. The range does not appear to even cover half of it.
Would someone kindly be able to recommend a range improver for this router? I am using it with a CM1000 modem with Comcast gigabit internet.
Thanks kindly.
Thanks kindly.
1 Reply
Theoretically the router probably could cover that area. As you've found out, practical application is a no. Many different factors influence this from building materials, types of insulation, where the router is placed, hvac runs, layout of the house, etc. Under optimal condions, it'd probably work. I've got a 3200 sqft house and use an orbi with 2x satellites for full coverage. I've tried a new AX router and the Orbi was still faster and had better coverage. So I went back to Orbi for now. Yes, the new ax specs has a slight extra range but I doubt any of your devices (maybe 1 or 2) actually have ax built in.
4000 sqft is what I'd consider a large house. If your still in the return period, I'd look at the orbi setup or an equivalent mesh setup with a satellite or 2 to fully cover your house. Especially if you've got a gigabit connection. A single router in that large of a house will struggle even if you're running the new RAX200.
