Belaus
Mar 04, 2022Initiate
RAX 40 Region Locked to North America Script Change won't stick
So in 'Wireless' the 'Region Selection' setting was lcoked on 'North America' and the drop-down was locked. I'm in Australia. I went into the script elements and deleted the 'disabled' in the text w...
Belaus
Mar 06, 2022Initiate
Hi, many thanks for your response. No, I'm accessing the Element code direct from Chrome by right-clicking on the Region Box and selecting 'Inspect'. That's where I can see that the Region text has a 'disabled' text in its string. Deleting it produces a drop down and allows me to select my (Australia) region, but on 'Apply' it simply reverts to its old setting.
I'm wondering if i'm missing something in the string, because i'm not a programmer!
Mar 07, 2022Guru - Experienced User
That doesn't reprogram the router. That's why it isn't retained. You can change whatever you want on the display code but since it isn't changing it in the router, nothing saves/changes.
The FCC locked the north american region for devices sold here.
You used to be able to telnet into a router to change regions. Sadly, netgear has been removing the telnet option for routers.
You can try googling telnet burnsku and see the instructions to see if it'd work for your device.
