t84a
Oct 04, 2023Aspirant
RAX-42 Port Based VLANs
This post is very similar to a post I made several years ago. I'm trying to mitigate wifi congestion. I want to assign 2 of the ports to 2 additional (separate) VLANs. I would run a couple Unifi...
Oct 04, 2023Guru - Experienced User
That's not supported on this or any model NG home class router. Most VLAN and VLAN Tagging is kept to the Manage switch domain.
You might check out Orbi Pro and see if there is any VLAN support that your looking for there.
- t84aOct 04, 2023AspirantThanks. The manual references setting up bridge ports.
Maybe VLAN was the wrong term.- FURRYe38Oct 04, 2023Guru - Experienced User
What page is that on?
I believe this model router only sports Router, AP and Wireless Bridge mode. Wireless bridge mode would let the LAN ports be used like a switch. Just no VLAN features here though. Just LAN ports for devices to connected to while in that mode.
- t84aOct 04, 2023AspirantPage 75
I tried to attach a screenshot but no success.
