t84a
Oct 04, 2023Aspirant
RAX-42 Port Based VLANs
This post is very similar to a post I made several years ago. I'm trying to mitigate wifi congestion. I want to assign 2 of the ports to 2 additional (separate) VLANs. I would run a couple Unifi...
t84a
Thanks. The manual references setting up bridge ports.
Maybe VLAN was the wrong term.
Oct 04, 2023Guru - Experienced User
What page is that on?
I believe this model router only sports Router, AP and Wireless Bridge mode. Wireless bridge mode would let the LAN ports be used like a switch. Just no VLAN features here though. Just LAN ports for devices to connected to while in that mode.
- t84aOct 04, 2023AspirantPage 75
I tried to attach a screenshot but no success.- FURRYe38Oct 04, 2023Guru - Experienced User
I believe that's for ISP that has some TV Services for there devices connected behind the router that require VLAN tagging. I guess you can try to configure it and see if it works for your needs to see if anything works for you.
If not, then a managed switch would be next. Maybe something like NGs GS-108T?
