PealDG
Feb 16, 2023Follower
RAX 45 - Internet LED is solid Orange
The internet LED on my router is suddenly Solid Amber and the router is not detectable. However when i connect my lan cable to the cable modem directly , i can connect to the internet on a wired conn...
michaelkenward
Feb 16, 2023Guru - Experienced User
PealDG wrote:
The internet LED on my router is suddenly Solid Amber and the router is not detectable. However when i connect my lan cable to the cable modem directly , i can connect to the internet on a wired connection.
Any solution to the problem
A reset is certainly a possibility but it is the nuclear option. You have to set up the network all over again.
There is a simpler and less dramatic one to try first.
It may help to reboot the whole network in the right order.
- Turn off and unplug modem.
- Turn off router and computers.
- Plug in and turn on modem. Wait 2 minutes for it to connect.
- Turn on the router and wait 2 minutes for it to connect.
- Turn on computers and rest of network.
If that does not work, then move on to the reset.
Before you do that you could save a backup of your current configuration and restore it when you are back on line.
If restoring it kills the connection, just reset again and set up the device from scratch.
