route123
Nov 24, 2021Aspirant
rax 45 unable to block porn website
Hello, I bought this product to block porn website for the home use, it turns out that it only block the manually added porn website. there are thousands of porn website and it is impossible for ...
Nov 25, 2021Guru - Experienced User
Did you try using opendns's family shield setup? you can simply use the DNS address for the family shield.
