route123
Nov 24, 2021Aspirant
rax 45 unable to block porn website
Hello, I bought this product to block porn website for the home use, it turns out that it only block the manually added porn website. there are thousands of porn website and it is impossible for ...
michaelkenward
Nov 25, 2021Guru - Experienced User
Did you check the specifications before you parted with your money?
Netgear makes a raft of routers, some of which are designed to do just what you want. But you have to pay for a subscription.
Unfortunately, the RAX40, unlike the RAX40V2, doesn't seem to be one of the devices that supports these features. Unless, that it, it has added them with new firmware. (This happens from time to time.)
Which products support NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
Other devices support Circle:
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Circle also needs a subscription.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
route123
Nov 25, 2021Aspirant
Hi Michael,My product is rax 45 and the parent control is supported.
Based on the talking with the netgrear support engineer, they didn't mention any subscription service.
they only offer to manually input the website to block. did I miss something?
thanks so much for the help
- michaelkenwardNov 25, 2021Guru - Experienced User
Yes, but what sort of parental controls?
In its wisdom, Netgear keeps changing the names of these things.
The old free version of Parental Controls is dead or dying.
Live Parental Control | NETGEAR
But as plemans suggests you don't have to use Netgear as an intermediary.
Home Internet Security | OpenDNS
