Razor004
Mar 31, 2023Aspirant
RAX 48 Ethernet Ports - WAN & LAN Ports stopped working suddenly.
Hi, I have RAX 48 and few weeks back the Ethernet Ports - WAN & LAN Ports of my routed stopped working suddenly. I have applied all the available firmware's at Netgear and still no use. Does anyo...
Mar 31, 2023Guru - Experienced User
Power OFF with pulling the power adapter after a factory reset for 30 seconds?
If nothing will connect, sounds like the unit needs to be RMAd.
Razor004
Tried the method. Still same. I think the router is gone. The whole point of BYOD is squashed.
