Dirtnapper01
Feb 21, 2024Aspirant
RAX 49 Access denied
I can not access the router....constantly get Accessed Denied. Any ideas.
Feb 21, 2024Guru - Experienced User
- Dirtnapper01Feb 21, 2024Aspirant
Reset took care of it, thanks.
- FURRYe38Feb 21, 2024Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
