slackrl's avatar
slackrl
Luminary
Jun 12, 2021
RAX-50 Router - OpenDNS Updater 2.2.1 Connection Failure
Purchased AX as replacement for Older Netgear AC router -Setup Router by loading firware .chk files manually -Current Version is V1.0.2.94_2.0.58 -After update performed Router Hardware reset. ...
  • slackrl's avatar
    slackrl
    Jun 13, 2021
    Problem Solved!
    At least on the wifi nic card.
    Found this from user (a santinelli ) on OpenDNS forum.
    The problem appears to be related to ipv6.
    Solution:
     -Open wifi nic card properties.
     -Open ethernet nic card properties.
     -Removed check mark in use ipv6.
     -Flushed PC's dns.
     -Rebooted PC.
     -Rebooted Router.
     -OpenDNS updater 2.2.1  looks normal.
     -Looks like no iternet connectivity. msg is gone.
    Pardon the double pic post  will test ethernet nic also
