shmitty7
Oct 16, 2023Follower
RAX 50 solid orange power light
When the RAX50 powers on the light under the power symbol stays solid orange, with the occasional flash to white every few minutes but then right back to solid orange. What does this mean exactly? I ...
michaelkenward
Oct 16, 2023Guru - Experienced User
shmitty7 wrote:
....the occasional flash to white every few minutes but then right back to solid orange. What does this mean exactly?
If you look at the manual, you can see what Netgear says:
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
The bad news is that it may have corrupt firmware.
If so, start simple and see if a reset will fix the thing.
How do I reset my Orbi WiFi System to factory default settings? - NETGEAR Support
Opinions vary on more severe resets, with some saying that the 30:30:30 thing is pointless. (In older routers it put them into "Recovery mode".) But if your router us bust, then you can't do any more damage to it.
Lastly, I tried pushing a firmware update to it using tftp and I'm just getting "Connect request failed."
TFTP is not the easiest operation to carry out. It takes careful timing. So you may have to keep trying until you work, or give up with exhaustion.
Can you think of anything that might have throw the router into a tizzy?
