benotdes
Mar 05, 2023Aspirant
RAX-70 second 5 Ghz band drops randomly
Hi, I hope all is well! I bought the RAX-70 router 11 months ago, mainly to have a router robust enough to handle my eleven HomePod minis and stream 4K movies on my Apple TV. I use the second...
michaelkenward
Mar 05, 2023Guru - Experienced User
benotdes wrote:
Also I have a 120 Mbps cable Internet connection for which the modem has been replaced two weeks ago. So the modem shouldn't be the problem.
And that modem is? Make and model?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
benotdes
Hi michaelkenward,
Thank you very much for your help!
The curent firmware is 1.0.14.134. As for the modem it's a Technicolor model TC4300.E.
Thank you!
