martinb0820
Apr 13, 2020Guide
RAX 75 debugging
I didn't see the RAX 75 listed, so specified the model as RAX 80. I'm trying to debug an issue where a device (Linux-based audio streamer) has multiple connections running, and some of them inter...
martinb0820
Apr 13, 2020Guide
Just to clarify - all the connections are WiFi. The laptop/Android-to-device connections are via the router as well.
- martinb0820Apr 13, 2020Guide
I just found nmap. If there isn't a hidden router capability, it looks like that should work.
