AggieChymist
Jul 12, 2022Aspirant
RAX 78 does not acknowledge internet without a switch
My RAX 78 does not acknowledge the internet coming in directly from fiber. Right now I can only get it to work by having the line come in to a 10/100 switch, and then to the RAX 78. Then it sees the i...
Jul 12, 2022Guru - Experienced User
You'll need to contact your ISP and ask them if there are any requirements they may have in regards to what may or may not be needed to connect the RAX directly to there ONT.
I would use a 1000Mpbs switch instead.
