glennanewman
Aug 06, 2021Follower
RAX 80 fails to upgrade at GUI Language update step
RAX80 at firmware version 1.0.4.120_2.1.46.1. Detects upgrade available to 1.0.5.126_2.1.46.1. Contacts Netgear server and stuck on the page labeled "GUI Language update" with message "Downloading ...
NtwrkRash
Jan 06, 2022Aspirant
I installed the router firmware manually 1.0.5.132. As I also got stuck in the language table loop. After the router firmware update I noticed that the language tables are still on version 1.0.3. I solved it by switching language to English (router webpage, right corner), than it will automatically install the new language tables, that came with the firmware 1.0.5.132, correctly and reboot.
