xidi_25
Apr 14, 2023Follower
RAX 80 lagging
I have a RAX80 router, ruinning in AP mode. Router works normally fine, but starts lagging even with hard-wired devices after some time. Latest Firmware running, have done several resets recentl...
Apr 14, 2023Guru - Experienced User
If its in AP mode, what router is it connected to?
That's usually whats causing the lag as in ap mode, the RAX isn't doing any traffic inspection/management at all. Its all the primary router.
- xididiApr 14, 2023AspirantAustrian internet provider #1 Austrian Telekom A1.
Huawei Hybrid router, no chance to reconfigure it.
But problems definitely come from RAX. Any chance to find out, which smart home device may cause this?- michaelkenwardApr 14, 2023Guru - Experienced User
xididi wrote:
Huawei Hybrid router, no chance to reconfigure it.Any chance of a model number? I suspect that Huawei has made more than one "hybrid router", whatever that is. Modem router? (Someone here may have experience with it.) Plenty of those certainly don't offer "bridge mode".
But problems definitely come from RAX.How did you determine that?
Any chance to find out, which smart home device may cause this?You could try turning off devices one at a time to see what happens.
But it is hard to think how a Wifi client can throttle a router. The usual complaint is the other way round, that routers slow down clients.
Huawei DN9245W-10
Hybrid, cause main bandwith comes in from wired ADSL, rest comes from 4G via air.
I have a second asus router on 2nd floor, no probs with this one.
when i reset the router, wifi is to default password.
so no connecttions at all. then the router works as hell.
so no devices conncted, all fine.
26 devices connected (currently half of them hardwired) -> lagging. even on the hardwired ps5!
