xidi_25
Apr 14, 2023Follower
RAX 80 lagging
I have a RAX80 router, ruinning in AP mode. Router works normally fine, but starts lagging even with hard-wired devices after some time. Latest Firmware running, have done several resets recentl...
xididi
Apr 14, 2023Aspirant
Austrian internet provider #1 Austrian Telekom A1.
Huawei Hybrid router, no chance to reconfigure it.
But problems definitely come from RAX. Any chance to find out, which smart home device may cause this?
michaelkenward
Apr 14, 2023Guru - Experienced User
Any chance of a model number? I suspect that Huawei has made more than one "hybrid router", whatever that is. Modem router? (Someone here may have experience with it.) Plenty of those certainly don't offer "bridge mode".
How did you determine that?
You could try turning off devices one at a time to see what happens.
But it is hard to think how a Wifi client can throttle a router. The usual complaint is the other way round, that routers slow down clients.
- xididiApr 14, 2023Aspirant
Huawei DN9245W-10
Hybrid, cause main bandwith comes in from wired ADSL, rest comes from 4G via air.
I have a second asus router on 2nd floor, no probs with this one.
when i reset the router, wifi is to default password.
so no connecttions at all. then the router works as hell.
so no devices conncted, all fine.
26 devices connected (currently half of them hardwired) -> lagging. even on the hardwired ps5!
- michaelkenwardApr 15, 2023Guru - Experienced User
xididi wrote:
Huawei DN9245W-10
Not a typical setup. Well outside my experience.I cam see plenty of room for chaos there.
I wouldn't know how to begin to merge ADSL and mobile. (My experience is with VDSL and a mobile modem when that fails.) Everything I read here suggests that it isn't even possible.
I have no idea what that means. I don't see how going back to the default (wifi?) password prevents things from connecting.
And with two routers broadcasting wifi I can see how wifi clients can get confused.
I think you are going to need help from pone of the resident experts here who has a better understanding pf network engineering.
- xididiApr 15, 2023Aspirant
So this A1 Modem is a std system here, you do not have to care to merge the 2 streams.
So no hassle here, we cannot change the mode of this router anyway.
When i reset the router to config password, NO smart device is conntected anymore.
No Google Home, no google tv, no ring-system.
Just the smart-phone to configure is connected. Then I have max speed, no lags, all good….
