sewsable
Mar 14, 2021Star
RAx 80 setting a static IP address for my Xbox
So I've had a few times where my Xbox is unable to find an IP address; I'm suspecting because the one it was using has been assigned to another device recently turned on. The information I found onl...
sewsable
Mar 15, 2021Star
I posted in here because my router is a Nighthawk RAX80 so it seemed like the right place. It probably doesn't need moving as I don't have an Orbi device, but thank you for looking.
michaelkenward
Mar 15, 2021Guru - Experienced User
My mistake, some of us aren't perfect. The redirect link I posted was the error. Your "in here" bit was also wrong.
You started in the Nighthawk section:
It did need moving, if you wanted ti reach the right audience. The moderator picked up my mistake and moved your message to the correct section:
Nighthawk Routers with WiFi 6 (AX)
My apologies.
The reason for using the right place is that these things can be hardware dependent. From what I read here, AX stuff seem to have quirks that are beyond the usual Nighthawk kit. (I guess that's why Netgear has this baffling array of sections.) It also has its own cabal of experts who probably try to avoid the mainstream stuff.
With luck you will now get the help you need. If you haven't tried it already, a search of this section might prove profitable.
- sewsableMar 15, 2021Star
Thank you, I appreciate your help; have a lovely day.
