Alexcabrils
Dec 08, 2022Aspirant
RAX blocking emails
My RAX 70 started blocking my email some weeks ago, its an intermitent issue, when is happening I can switch from the wifi to my phone hotspot and everything works normal but when I go bacj to wifi t...
Dec 08, 2022Guru - Experienced User
Is it only happening on your phone? Or does it happen on pc/laptops?
What device is it?
If its an ios device, try disabling icloud relay and private mac/ip address.
Alexcabrils
Hello, is happening everywhere, iphone, 2 macs and ipads... everything connected with the router by wifi has de problem.
- plemansDec 08, 2022Guru - Experienced User
What firmware is on the router?
What modem/gateway is it connected to?
are you using a vpn?
- AlexcabrilsDec 08, 2022Aspirant
Can this option has something to do with the problem?
Enable AX - This WiFi mode will enable AX features such as OFDMA
Probably I'm repiting the message sorry for that:
Router Firmware Version V1.0.13.128
Modem SB8200
No VPN
When I click on the warning icon beside the account name in mail I have this message:
Connections to the server on the default ports timed out.
AX shouldn't block a specific program.
Do you have IPv6 enabled on the router?
Are you using armor?
